Status
Not open for further replies.
1 - 8 of 8 Posts
Working on a 1998 Chevy k1500 5.7 350. 4L60E trans. I have the ATSG Manual and the ATSG update. Can any of you experienced transmission builders confirm what updates must be done. Most of the updates in the manual are for older model years and I just want to make sure I have done every last one that is needed.
Also does anyone have feedback from the Monster Transmission rebuild kits?
Thank you in advance.
sonaxx .490 oringed boost valve provides more line psi under heavy acceleration
sonnax tcc regulater valve will need a reamer to install it prevents tcc slip and dtc 1870 burn clutches
sonnax tcc apply valve goes in the pump
trans go seperator plate and trans go jr shift kit
corvette servo
transmission parts usa is in fla it takes 3 days to wva they have ok deals but sells sonnax get the part numbers find a local tranny shop to order them from transtar
1 - 8 of 8 Posts
Status
