Status
Not open for further replies.
1 - 2 of 2 Posts
I have a rebuilt 4L60E that was just rebuilt. All gears shift good but when you put it in reverse it is like you are on the brakes with the emergency brake on. The engine hardly revs up even when floored. Any ideas? I tried to send it back to the people that built it but they are avoiding me. Long story but lesson learned. When I talked to them about it, they said there is something wrong with the valve body. Do I need to replace the valve body or is there a part I can change without taking the valve body off. it is in a 96 z71 and I am trying not to take it back out if possibable. Thanks in advance
Hate to say it but sounds like you have to pull it back out the 4l60e does have some issues in the valve body that should have been addressed when it was rebuilt however the symtoms you are explaining could also be leaking lipseals are clutches improperly installed in the rev drum or damaged hard parts like sprags, etc.
1 - 2 of 2 Posts
Status
