I've got a 68 camaro with a M20 4-speed transmission, and I can't seem to permanently fix my throw-out bearing problem. It started with the old engine in the car. I had to replace it 3 times because when the clutch was pressed in, it would make a annoying spinning noise. Since then, I've put in a new engine (same as old 350), and a new performance clutch with a "longer" performance throw-out bearing. There are less than 500 miles on the clutch, and the bearing is making a noise again.
Obvisiously to go through 4 throw-out bearings in under 5000 miles is a bit ridiculous. Any clue what might be causing this problem? I'm frustrated to no end and would really like to fix it for good! Thanks so much!
