firestone said:
One other idea is to sell the parts you have and start over with a set of AFR 195cc heads with a hyd roller on a 383, that can easily be a 500 hp, ~500 tq combo with the right cam.
Good luck
Adam
Sometimes I think Adam gets commission from AFR
But I agree with him on this issue, and maybe I am a little bias toward AFR as well. Before building my 383, I put a lot of thought into heads. I had a set of Performer RPM heads on a 355, but noticed that you never see any 450+HP (N/A) engines that use them (published articles). At least I haven't.
What I did notice is that American Speed Enterprises, who gets tremendous magazine exposure, uses the Edelbrock heads on 355 and 383 engines that they build to about a 450 HP limit (which includes some porting). Above that, they use AFR 195 heads almost exclusively. Check out their different dyno tested builds
here.
You can also read a number of magazine articles at AFR
here. Go to the articles and dyno tested combos sections. You can build a 500HP 355, but as Mad Maggot said, you will need a big cam (like 240+ @.050) and a lot of RPM.
Here is one example. And IMO, it would also need over 10-1 and a head such as the AFR 195.
There is nothing wrong with the RPM heads. But, if Edelbrock were to build a 450+HP engine, I'll bet they would be the first to dump the RPM heads, and upgrade to something like their Victor Jr. heads, which are more comparible to the AFR line. Again, this is just my opinion.
Good luck making your choice. Ed
www.edgesz28.com
