Going way back...
Doc here :pimp:
Going way back in memory...Wasn't the fuse box mounted on the Fender well under the hood? ... I seem to remember something like that, but it was on a 51 ford truck..Long, Long ago...Foggy memory when ya get to be my age...
As far as The turn signal, Are you saying it works on the lane changer, but not in the fully on position?
If so, that Typically is bad or Dirty spring clips or contacts inside the column Housing at the turn-signal plate..Clean the contacts and repair or replace the spring clips.
Hope it helps!
Doc :pimp:
no nothing works the lights dont even light up thanks for the help on the fuse pannel i will take a look to see if i can find it if i cant no big deal because i will find it when i re wire the car
