This may be long and somewhat confusing so bare with me. I have a stock 56 Belair 265 cu.in V-8 two barrel carb powerglide. The problem is upon acceleration it falls flat on its face like it is out of fuel. This is what I have done thus far.
New carb (actually have tried three carbs) no change in condition
new points, plugs, condenser no change
new coil and resistor no change
totally by passed gas tank and fuel pump with secondary systen no change
cleaned and freeded up the exhaust manifold heat riser no change
tried two new distributors no change
reset carb float level no chage
timing is slightly advanced played with it no change
Car starts right up idels smooth and takes acceleration fine with no load runs fairly well once you get over 20MPH completely cuts out from a dead stop or if you try to take off quick it simply stalls and dies. I have NO idea of what to do moving forward any ideas?
