Here is a good one for you blower guys. I have a 8.5 to 1 468 BBC w/hyd roller cam. Motor is on a run up stand and did run very good. Other than the cam this motor is pretty much stock. I have installed a USED Weiand 6-71 on it. It came off a SBC so I had to buy the Intake, pully parts, and belt to make it fit the BBC. The intake is new. The carbs are matching 600 Holleys. I am running 39 tooth on the blower and 35 tooth on the crank, 9 percent. Here is the problem: As the motor turns over I can feel the vacuum pull through the top of the carbs but as soon as the engine starts, that vacuum pull goes away and it dies. The RPM is very high which I am sure is due to a lean condition. It is just burning the fuel I pumped in it to get it started. Carbs are fresh but not mine so I changed to a single 850 that I took off a running race car to eliminate the carbs as the problem. No change to the running condition. It acts like a vacuum leak so I siliconed the blower to the intake and the carb adapter to the blower. NO CHANGE AND GETTING FRUSTRATED. Got any ideas??????? Sarge
