1 - 2 of 2 Posts
so i am planning on swapping out the motor from my 63 falcon that is a 170c.i. to a 74 maverick 302. what i need to know is will the accelerater linkage match up and if i should plug up any vacum hoses for it. also what rear end would be best to put in for the new motor.
your going to want the Maverick gas pedal assembly.. it'll be a bolt in swap.. rear end, front spindles, brakes ( M/C too ).. should be able to make the frame stands work... other than that. the Maverick steering box/ column.. it should all bolt in a there the same basic chassis.. you'll need tie rod adaptors from www.discbrakeswap.com but other than that. it should all bolt in
1 - 2 of 2 Posts
