My axle is leaking at the wheel. This is the rear end without an inspection plate on the differential. Any experience replacing the seal? Local shop wants $200 per wheel.
As one of the Moderators here.......let me be the first to WELCOME you here. :welcome:
You remove the wheel/tire/rim and then the brake drum.
Remove the 4 bolts that hold the axle in (to the backing plate).
Then use a axle puller and pull the axle. Then you can replace the seal. New wheel bearings are a great preventive maintenance move also.
Reverse the procedure.
DEUCE ......General Rodding Tech Moderator.
:D
