he's right bad rear seal easy fix just drop the drive shaft and pull it out remove old seal and put in a new one and replace drilve shaft. any tranny shop can do that in no time flat.
Just stuck
If it's leaking through the splines, you can change all the seals you want and the leak won't stop. It's most likely the cap or welch plug in the back of the yoke leaking. You'll need to pull the yoke off the u-joint to get to it. Either replace the yoke or clean it and seal the plug.
