when i push on the throttle, i hear the weber sucking in air, but when pushing it far i hear like a valve rattling (comp when sucking on a straw, glas as good as completely empty.) than some smoke exits the engine via the exhaust.
doing about 60 Mph the engine makes a big noise( maybe because its position) consuming some oil. and 75Mph would be about max i will go because of noise and my mechanics feeling says me to stop there.
also when heated up, the starter motor seems to have lots more issues to crank the motor. (compression going up maybe..)
first step... the Rattle.. on acceleration.. could it be pinging.. too much advance too soon.. perhaps lack of fuel flow and the engine running lean and pinging.
i would want to use a timing light with an advance knob.. and a tachometer.. a vacuum gauge is going to help also.. along with some fittings. perhaps a hand vacuum pump.. this is for diagnostic charting of the timing curve only..
distributor vacuum disconnected.. what is the base timing set at .. and at what RPM. slowly increase the engine speed till it stops moving.. at what speed does the centrifical stop advancing, write that rpm number down. you also want to write down how many degrees it advanced.. you will want to do this twice.. once with the timing light knob on Zero and you will bring the knob to move the light to TDC. .. the other with the advance knob set to bring the advance at idle to zero. this is double checking.
now.. do the vacuum advance. start slowly applying vacuum till the advance starts moving. note the vacuum reading.. you can do this at idle.. you don't have to it for more than a few seconds.. then apply 5 inches of vacuum.. see how far it advanced.. apply 10 inches of vacuum and see how far it advanced.. do 15 inches of vacuum.. see how far it advanced..
you can see what maxium advance..
you might want to Tee into the vacuum advance hose and put the vacuum gauge up in the window so you could see how much vacuum you get to the advance driving around..
this is all diagnostic stuff.. its up to you if you want to perform this.. it usually takes 20 to 30 minutes to do this..
next... a voltage drop test..
http://i.imgur.com/WMDprhm.jpg
i am going to ask that you create a extra test wire.
Ring terminal... wire------------------ female bullet connector..
this allows you to measure voltage drop at the starter motor really easily.. so after you have performed the other six steps.. step 5 goes to the starter relay on the inner fender or actually in the dog house in your van..
test 2, 3, 4 should be done a second time while starting/cranking the engine..
the custom 16 gauge wire from the starter to the digital volt meter set to 20 volts DC.. the other test lead hooked to the positive battery terminal.. i would love to see less than 1.0 volts while cranking.. i would expect to see less than 2 volts.. if you have more than that.. you need to go thicker on the positive cables..
you can do test 2 while cranking to check the negative cables.
there is a COLD engine test to perform.. disable the ignition system. disconnect the fuel line into the carb.. stick it in a clean clear plastic soda bottle.. have somebody crank the engine for 15 seconds while you observe the pulses of fuel... again this is a diagnostic test as these all are.. if your fuel pulses diminish or just are not as full as you think they should be.. you may need to go farther.. to find out why..
i usually blow into the fuel line.. i should not be able to blow backwards thru the pump and should not be able to blow bubbles in the fuel tank.
these are all tests that i do sometimes daily..
i can explain why for each test.. more than i have.
