I was wondering if there were any tips to beef up a 302 mustang engine i recently purchased, some things to boost up from only about 200 hp. Looking to mark my classic intimidating :evil: ... Thanks.
Around here you can get good used 5.0 roller engines from between $500 and $1000. You couldn't buy half the pieces listed for that much. He only wants about 200 HP and that is less than most GT engines make, plus they come with factory headers...sure they aren't the best,but are plenty good enough for the HP range he wants. I mean, The HP rating is WITH the factory headers so they have to work well enough for that.onebadmerc said:I would get headers and some good 2 1/4" or 2 1/2" turbo mufflers and run a dual exhaust first. Then I would upgrade the ignition from a points system to a electronic ignition. I would then get a good dual plane intake manifold and run a 500cfm-600cfm carb. The last thing I would do is get some good aftermarket heads and a cam to match them if your budget allows for this. This would be about the best way to increase HP for the least amount of money in this order.
