Hi.
My dad has been having a lot of problems with his truck recently with this motor. He recently asked my cousin to help tune his engine, the engine is now idling amazingly and will start perfectly. The only issue is when he puts the truck into gear, the truck will either have rough RPMs or will stall right away. The only way to counter this is by turning the idle RPM up to 1500+and it still had some troubles staying running
These are the specs of his engine
Board over 30
Eagle stroker crank
Heads were shaved same with block
HEI-MSD distributor
Comp Cam 548 lift
700R4 Auto transmission with 2500 stall converter
that is everything that he knows about it. Something i should add is when the truck is moving, the truck will drive smoothly. Personally i think it’s the stall converter. I’m just trying to find the cheapest option to fix this issue. Oh and my dad ripped out all of the computers in his truck, so all tuning is done by hand
Board over 30
Eagle stroker crank
HEI-MSD distributor
Comp Cam 548 lift
