1 - 7 of 7 Posts
Hi everyone, I have a 1968 C50 with a 366 ID in it.
I am looking to find out if the firing order is the basic Chevy big block firing order. Or if it is different due to the crank spinning clock wise and the cam spinning counter clockwise. Two gears. Nothing inbetween on the front of the block. - everyone I talk to says different. Either it’s the same or it’s different.
Long story short I took the timing cover off to replace the timing chain and found out it is a gear driven driven. It has a camshaft gear and a crankshaft gear none in between.
I ended up putting new distributor parts in it, new timing cover gasket, new oil pump. And a few other odds and ends.
Thanks for the help
524417
1 - 7 of 7 Posts
