It appears that this question has been thoroughly answered, but here is some additional info for what it's worth....
If those terminals are 1/4" wide, they go by the name "Delphi Packard Metri Pack 56" formerly known as "Packard Electric series 56" terminals. They are very common in GM products built from the late 50's up into the '80's.
I buy them from the following places:
DelCity
Waytek Wire
They are also available through
Auveco, which could be ordered from most major auto parts stores and nut & bolt stores.
They are available in different sizes to match the size wire they are to be attached to, so make sure you get the right size.
The male terminals can be especially difficult to crimp properly without the proper crimper (which is spendy). I recommend that you also solder them if you do not have access to the proper crimping tool.
I use
this crimper, but most heavy duty roll-over style crimpers will do an adequate job.
I am sure these terminals are also available through any of the major aftermarket wiring harness manufacturers such as American Auto Wire, Painless, Ron Francis, etc.
Hope this helps... :thumbup:
