1 - 6 of 6 Posts
Hey guys, i recently was given a 68 Lincoln Continental. Its been sitting for 20+ years. The woman that gave it to me parked it in her yard so it was running fine.
Currently the engine compartment is covered in leaves and has a rats nest.
My question is what would you recommend to get this engine running. I checked the fluids and nothing is dry. The oil is dark, brake fluids dirty, trany smells terrible and p/s is full. Motor has little under 60k, no visible oil leaks.
This is my first project car and i want to make sure its done right.
Thanks:welcome:
Discussion Starter · #2 ·
Yeah i figured i would need to do all that. I did some research and a lot of people are saying to pull the plugs and spray some wd-40 and let it sit for a wile. Its hard to do anything right now because of the location of the car. Its on a gravel road, the tires are shot so im probably just gonna do all the work where its at until i can get some tires on it so i can pull it out and get it on a flatbed.
So far my plans are to get it running and then tear out the interior and basically restore it. I have a buddy that does body work and i could do all the mechanical. Its gonna take a long time and a lot of money but im young, i got time lol.
Old(s) Fart
Plan on replacing all the rubber parts in the brake and fuel system. I'd rebuild everything in the brake system (M/C and wheel cylinders) and all rubber hoses. Rubber fuel hoses from tank to hard lines and hard lines to pump should also be replaced. Expect the carb gaskets to be completely dried out and leaking, so plan on a carb rebuild as well. New plug wires and tuneup, of course, assuming the engine turns over. All new fluids and filters. Finally, carefully inspect the wire harnesses for signs of rodents chewing the insulation and repair any problems to avoid a fire.
Premium Member
I would do as little as you have to where its sitting. On gravel is not a safe place to be using a jack or even stands. If you just need to get it running long enough to get it on a trailer, frankly I would just do the bare minimum. There's not very much you can do that's going to take 20 years of wear off the motor from sitting there. If you want to fog the motor, thats fine I don't think it will help much. I would not try to get under it to change fluids/parts. Wait until you're in a safe location before you go horsing around with all that.
K
If you plan on flat bedding it home, just do it now....those guys have winches on their trucks capable of hauling it aboard, flat tires or not.......Then it will be where its safe to work on. Personally, the only thing I would want off that is the drive train to put in something much lighter
moving dead cars.
Sometimes I take a sheet of 3/4 in plywood and have it in front of the car so when it starts up on my trailer the plywood will slide easier than metal parts of the car hanging up and getting bent, some times jack up the front of the car to reposition the wood sheets. on my tilt trailer I have 1/4 in steel plate floor, and I have hung up stuff where the weld beads are. but parts can start to gouge on the clear floor areas too.
1 - 6 of 6 Posts
