swapping my 2 speed powerglide for a turbo 350 any pontiac guys no if this is an easy swap or will i need different mounts or anything..........
Maxpenguard1971,
I am not a Pontiac guy but I believe this is a straight forward swap. You might need a different crossmember but you could just make an adapto-plate to make yours work.
I would also check the shifting linkage to be sure it will line up. Also the "kick-down" cable might be different at the carburator end. Just check it out before you take anything apart. And be sure to measure everything.
Scholman
