1 - 1 of 1 Posts
69 Camaro coupe
having trouble getting the horn to work on my 69, its got a non tilt steering column. I just installed a new cancel cam. Grant steering wheel with Grant installation kit. No signal going to the relay. I ran a multimeter doing a resistance check (Ohm) between the horn button ground wire and the steering column wire cluster. No response on any of the points in the column harness.
Any suggestions before I open up the column again, I'm suspecting the cancel cam isn't making connection through to the button?
1 - 1 of 1 Posts
