Evening guys, greenhorn here.
I have a project 1969 corvette with a small block 350 in it. Engine was in the car when I bought it. This detail will become relevant later.
I'm running 461 heads, 2.02/ 1.60 valves. The ports in the heads appear to be unmodified but slag free, but I'll admit it I'm a complete newbie to this stuff, so my eye isn't trained to spot porting. Perhaps they were undercover ported? Vintage holley street dominator single plane manifold, part number 701R1-3001 topped with a 650 cfm holley 4165 carburetor. Solid flat tappet camshaft, idles choppy but not enough to have any issues idling. Stamped rockers, screw-in studs with guide plates, long tube headers. Cranking compression is 140-150 psi per cylinder. Stock bottom end in a 010 block. Finally, it's got long tube, 1 5/8 diameter primary headers. Engine runs on pump gas. Still need to verify base timing.
I'm trying to get an idea for how much horsepower this thing might make before I make the decision to buy more modern speed parts for it, as I suspect that this engine was built in the 80s or the early 90s. My educated guess says low to mid 300s, but I'm too inexperienced to really have an idea. At the same time, I'm fully aware that the rear ends of these cars get squirrely easily if one isn't careful, so I don't want to make too much power with it. If anyone has their own .02 to throw at me, I'm more than happy to hear it.
Eric Nova, if you're reading this, your input is always, especially appreciated.
Thanks, guys!
Thanks, guys!
