.......keeping the same engine/gauges - if so, you will have some problems. Starter will run backwards though a 6VDC starter will work on 12VDC - as long as polarity is right, generator - will need to be replaced or better yet, install an alternator, gauges will need to be replaced or modified along with all senders. The lights - they don't care except they need to be 12VDC, the ignition system, will need a different and 12VDC coil. New condenser for neg ground, tho the points don't care either. New 12VDC ballast resistor. Radio - wont work (if it has one).
Now, if you are changing the drive line to something modern - it will all be neg ground - but the gauges and senders still need to be changed
