Also be aware, depending on how long it was run knocking, the "knock" you hear isn`t the big end of the rod slapping the journal, you hear the piston contacting the head. So if it was run a while the piston will have to be replaced. A friend of mine`s engine let a bearing go and he drove it maybe 15 miles home. He did a rebuild and I told him to replace the piston, he didn`t listen or didn`t believe me one. Anyways, after he was finished it ran good but he only got around 600 miles on it before the piston in that hole let go, bending the rod and the wrist pin wedged into the cylinder wall. Again, he drove it home which was only 4 miles away, upon tear down we found a huge gouge that was very close to finding water. Needless to say, the block was trash so it was junked. His engine and troubles could have been saved by a 15 dollar replacement piston.
