You will gain about 100 psi by using the larger booster. Whether or not it will be enough to satisfy whatever the deficit is, I cannot say w/o more info.Is there that much difference between a 7" and 8" dual boosters power assist capability? I've got about 16 vacuum at idle will I gain much by switching from a 7" to an 8" dual booster?
Got stock S10 front disc with S10 Blazer rear disc, good stopping power would like more, was thinking about changing to an 8" dual booster. The MC is a Corvette syyle with aftermarket under-the-floor and mount/pedal.You will gain about 100 psi by using the larger booster. Whether or not it will be enough to satisfy whatever the deficit is, I cannot say w/o more info.
Was the caliper bore diameter taken into account when the MC was bought? I ask because there are several different 'Vette MC bore sizes available.Got stock S10 front disc with S10 Blazer rear disc, good stopping power would like more, was thinking about changing to an 8" dual booster. The MC is a Corvette syyle with aftermarket under-the-floor and mount/pedal.
Less effort at the pedal w/more pedal travel can be done by a pedal ratio change. This is the easiest thing to try and I would do this first before changing the bore size, etc.The MC bore is one inch and the pedal assembly is an aftermarket under the floor. I've got 2lb residual valves on front and rear, no excessive pedal travel. Braking response is good would like a little less pedal effort.
