Hi, im about to tackle a dics brake conversion on a 70 le mans. So im wondering what donor car do i need and what other part do i need. I can get salvage parts no problem so the less new the better. Thanks, Jake
Any A-Body 69-72, Chevelle, Skylark, Grandprix, Cutlass etc.. You'll need the spindles, rotors, calipers, proportioning block, master cylinder, booster. Use the calipers & master cylinder for cores & get new. Brake hoses, retaining clips & frame brackets are different also. New wheel bearings, seals & hoses.jake_arcticcat said:Hi, im about to tackle a dics brake conversion on a 70 le mans. So im wondering what donor car do i need and what other part do i need. I can get salvage parts no problem so the less new the better. Thanks, Jake
The A-body steering arms are different, but these bolt on so they can be used on the X-Body spindles.1ownerT said:The 68-74 X-body has the steering components behind the centerline of the spindle, the A body are in front.
