I moved this thread to Transmission forum
I moved this thread to Transmission forumHaving trouble with 700 r4 torque converter
mounting up to flex plate. Cannot seem to get
it to go into the 2nd notch.
Any help appreciated.
Not that I'm any expert, but what do you mean by "second notch" ?Having trouble with 700 r4 torque converter
I guess I should have said 2nd clunk when mating up converterNot that I'm any expert, but what do you mean by "second notch" ?
You have the converter fully installed into the transmission as you position the converter to the flexplate on the engine?I guess I should have said 2nd clunk when mating up converter
to flex plate.
The only second clunk, I can imagine is when pushing the converter into the transmsion and rotating it to fully engage the transmission and pump. If you do not do that, then it rarely will allow the bellowing to mate to the engine and folks crank down the bolts and bust the pump.Having trouble with 700 r4 torque converter
Thats probably what happened a busted pump. Where is pumpThe only second clunk, I can imagine is when pushing the converter into the transmsion and rotating it to fully engage the transmission and pump. If you do not do that, then it rarely will allow the bellowing to mate to the engine and folks crank down the bolts and bust the pump.
So, as 49 Ford below states, when the transmission is mated to the engine, then the converter moves forward to the engine flex plate and is bted down. No clunks required.
Watch a YouTube video on 700r4 or 4l60 and you can see. They could be easier but not horrible.Thats probably what happened a busted pump. Where is pump
located, and can an inexperienced person replace it, and how expensive
are they? Thanks RD
With the transmission out and converter off it’s the very first thing you see, it will be more or less round in shape with a circle of bolts. They can be pretty pricy.Thats probably what happened a busted pump. Where is pump
are they? Thanks RD
