CHEVY BIG BLOCK 572
i got a 68 camaro 350/700r4 when i put car in gear i can drive aout 15mph and it wont shift into second i will shift into rev.it goes into low gears fine? so i got a trans out of 90 van will i didnt get the torq convert so i thought id use my old one went to put trans in today and the torq convert wont fit i tried for bout 2 hours i dont know whats the deal i have my old trans just in case i might be doing something wrong??????? :drunk: :drunk: :drunk: :drunk: :drunk: :evi
oh yeah will a 200r4 torq converter work with a 700r4?
Trans will not upshift? The TV cable not hooked up and adjusted correctly is one possible cause. A broken plastic governor gear is another possible cause for no upshift.
200-4r converter will fit early 700r4 trans. This would be a 27 spline input shaft on the 700r4 trans.
If you are trying to install a 27 spline 200-4r / 700r4 converter onto a 1990 4L60 - 700r4 trans with 30 spline input shaft, converter will not fit.
CHEVY BIG BLOCK 572
torq convert
no the trans spline is 27. just wondering if the converter will fit?
CHEVY BIG BLOCK 572
what is a broken plastic governor gear is another possible cause for no upshift?
