I installed a Transgo shift kit some time ago, and noticed at the time that the 2-4 servo seemed a bit sloppy but I used it anyway (see the video link below).. From the numbers on it and the dimensions, I'm 99% sure it is/was a Corvette servo assembly. The Transgo instructions say to discard the cushion spring, etc... Lately, as temperatures around here have risen (90 degrees a couple of days ago), my 4th gear shift speed go way up to 65 mph. I can always tell that the shift point to 4th is a function of the fluid temperature (viscosity). When it's cold, it shifts like a dream, and the warmer it is, the higher 4th shift point.
So, about a year ago, I bought a Sonnax Super Hold servo (with both 2nd and 4th booster configuration, the complete set of parts). Since I can't find the original cushion spring (I never throw anything away), and it appears that there are TWO different OEM cushion springs, I don't know which one to buy to install in the Sonnax, as it says "use OE cushion spring". then add the "OE Corvette Cushion spring, which I'm sure that it's the 08681195(??) spring that is meant to soften the 1-2 shift and soften the 3-2 downshift....
Problem is, there are two cushion springs as listed on Rock Auto, 08642539 (Pink) and 08642273 (Orange). I've googled the crap out of those numbers and have not been able to find out what the difference is between those springs.
By the way, anybody know what the color/dimensions the OE 2nd Gear Release Spring???
I have not taken the Transgo/Corvette/modified servo out yet ..as it's my daily driver and need to have everything I need before taking it apart...
Too bad Sonnax doesn't include all parts so as not to have to use "OE parts" to reinstall the servo.
Thanks in advance for the help !
Here are some links...
49fordcoupe.smugmug.com
The second time I rebuilt the transmission, I SHOULD NOT have put the servo back in... shoot me..here is a short video, most likely my problem
UPDATE: This 2-4 Servo was removed and a SONNAX full kit was installed. See Chapter 2 for the installation of the SONNAX. .....As it turns out , the numbers on the 2nd piston are TranStar part numbers (61986-1 and -2 with another mark - T/S which I guess means TranStar), which indicate some sort of after market Corvette servo, maybe....The diameter of the 2nd piston shoulder that slides into the housing is 1.75". Don't know what a Corvette servo is supposed to be..
UPDATE: The transmission worked really well after some tinkering with the throttle position cable, the governor springs and weights, removing the internal thermostat (had failed) and replacing the 4th gear pressure switch which allows lockup in 4th. ATTENTION! BE SURE TO CLICK BACK ON "HOME" IN...
UPDATE: April, 2021...I installed a Sonnax 2-4 "Super" Servo. See page 2...Original gallery notes............. VIDEO ! Although this looks waaay loose, when assembled, the pistons ride on the center pin, and are held in position for longitudinal movement. With new slash cut sealing rings, it fits much more snug.
ATTENTION ! ! If you are going to rebuild a 700R4/4L60, even if you know what you are doing, you MUST watch and follow the instructions in a series of YouTube videos produced by Transmission Bench. (http://transmissionbench.com/4L60Evideos.html). They are more than thorough in a successful...
