This is a very lengthy post and I apologize in advance. I respect the opinions of the hotrodders and tranny guys here who take the time to answer a novice’s questions. I am an old hotrodder in both senses (age, and technology) but, I do like some of the high tech stuff. Exmaple: GM's EFI and electronic trannys, the 4L60E to be specific. I have researched this board and many other boards for the last 8 months or so, and I have come to one conclusion NO ONE can agree on how to build, (what parts to use) a solid street, occasional strip tranny that will also be used for towing. I am a novice at building trannys, and I think I may have overdone it, but here is my scenario: a 3500lb vehicle with an mild EFI engine (350hp, 350lb/ft) through a 4L60E to a 12-bolt rearend.
Here is a parts list going into the 93 - 4L60E tranny.
Super Master Rebuild Kit
- Borg Warner Reverse Clutches and Raybestos Steels
- Borg Warner Forward Clutches and Overrun Clutches, all with Raybestos Steels
- Borg Warner "Hi-Energy" 2-4 band
* - Borg Warner 3/4 "High Energy" Clutches
- Borg Warner Lo-Reverse Clutches and Raybestos Steels
- Viton input-output shaft seal
- "Vette" style servo
- Teflon coated pump bushing
- All papers,gaskets,o-rings,etc
- Pan gasket
- Filter
* - Raybestos X-32 single sided 3/4 clutches (Z-Pack)
TransGo Shift kit (TG-4L60E-HD2)
- .500 4L60E specific boost valve
- many other pieces
TransGo HiRev Pump Kit
- unbreakable rings
- pump priming spring
Other Pump Stuff
Pump Slide (10 vane)
New pump vanes (10)
Pump Rotor (10 vane)
Rotor Guide (10 vane)
Hardened Stator shaft
Rostra TCC Solenoid.
Sonnax Torque Converter Clutch solenoid snout w/anti-drainback valve
Sonnax TCC Apply Valve
Sonnax Pump Slide Pivot Pin
Sonnax Pump Slide Spring Spacer
Sonnax High Output Pump Slide Spring
Heavy Duty Borg Warner, dual cage 29-element Forward Sprag assembly
Torrington Bearing Kit
Thrust Washer Kit
Bushing Kit
Sonnax Wide Reaction Sun Gear Bushing
Sonnax Wider Rear Stator Bushing
Hi-RPM 3-4 Clutch Spring Kit
HD BEAST Sun Gear Shell with Washer
Sonnax 4th Gear Super Hold Servo Piston
24208576 Oil Filter Kit (Extended Neck) w/Gasket for use on extra deep pan.
24215535 4L60E Extra Deep Transmission Pan w/Torx Head Magnetic Drain Plug
- adds an additional 2 quarts of capacity
24210961 4L65E Hi Torque Input Sprag assembly package
- 29 element SKF sprag, overrun clutch hub, retainer
- inner & outer races, snap ring, and sun gear
24218063 4L65E Carrier Assembly, Input
8663639 Gear, Input Internal
24222756 4L65E Shaft, Reaction Carrier
24217328 4L65E Bearing Assembly, Thrust (input carrier to reaction shaft)
24227002 4L65E Carrier Assembly, Reaction
24219411 4L65E Gear, Reaction Sun
24217143 4L65E Gear, Internal Reaction
8681491 Support, Internal Reaction Gear
8681295 Reverse Input Housing
8681727 Support, Low Reverse Clutch
8673300 Race, Lo-Reverse Roller
7471008 Clutch Assembly, Lo-Reverse Roller
24205272 Bonded Steel forward piston
24200290 Bonded Steel 3-4 clutch piston
8685043 Ring, 3-4 Clutch (apply) #7
8685044 Plate, 3-4 Clutch Apply (stepped)
15320479 GM Internal Wiring Harness
10478131 GM 1-2 & 3-4 shift solenoids
24227792 GM 3-2 shift solenoid
24212327 GM Pressure Control Solenoid
24219581 GM Pressure Switch Manifold
Sonnax Reverse piston capsule
Sonnax Servo release check valve
Sonnax Forward reverse abuse bore plug
Sonnax Accumulator valve train assembly
Sonnax Enhanced Performance 1-2 Accumulator Spring (5)
Sonnax Pin-less Forward Accumulator Piston Kit and Seal Kit
Sonnax Pin-less Accumulator Piston Kit
24202310 L35 GM Torque Converter
Stacked plate cooler with fan
My question is, will the 2001 - 2004 4L65E (M32) internals listed above fit in my 93 4L60E? Please make any comments/suggestions about my “rebuild package”.
Regards
Hotrod55man
- Pan gasket
- Filter
- many other pieces
- unbreakable rings
Other Pump Stuff
New pump vanes (10)
Thrust Washer Kit
Bushing Kit
Regards
Hotrod55man
