Okay, so we got caught up in a flash flood the other day, and my tranny took on some water. Anyhow, I only drove it 5 miles from where the flood about swept away my truck, and let it sit, until I could flush it the next day. So I'm pretty sure I've gotten 95% plus flushed. Anyhow, I drive an 89 S10 Blazer and I am pretty sure I have a 4L60/700R4 tranny. I do not think it is a 4L60E as those came out a couple years, I believe. Anyhow, I pulled the valve assembly apart to clean what I could out, and found check balls falling all over the place! Of all the research I have done trying to locate proper positioning for these, the only pics I can find are for 4L60E trannys, and the valve assembly's look quite different. I have found 9 Check balls total (8 of them 1/4 inch and 9th is slightly larger). I have included pics of where I believe these go. I need some help confirming whether or not I am right or not. I don't wanna have to do this again. May as well get it right the first time. And if anyone can confirm how many check balls total? (This is including one that is nestled in the valve body in a sense that I believe it's probably supposed to stay there....)
Here is the pic of the cover and where I have the check balls positioned in it. All 1/4 check balls in this one:
Here is the 1/4 ball nestled in the valve body, near the rear center closest to tranny mount:
And finally, the ones that go on top of the separator plate, the largest check ball in shown, where I believe it goes:
Any help on this time consuming, pain in the arse, hope I get it right matter would be GREATLY APPRECIATED!
