Hey feelas- I am puuting a 700R4 into my 34 Olds coupe and have a question about mounting it up. The original frame is pretty beefy and has an X member in the center of the frame. There is just about 14 inches between the two sides of the X member at the tranny mount holes and it looks like I am going to have to fabricate a cross member to mount it up. The question is this- How much torque is likely to be placed on the tail end of this transmission and can I get away with a cross member that just sits between the X member rails or should I extend the cross member all the way out to the frame rails? I'll be running a 450 hp small block and won't be racing the car but I will likely drive aggressively at times. I look forward to your thoughts on the subject. Thanks in advance. Mike
