hope someone, anyone can help! ive replaced every seal, o-ring, clutch, steel, n gasket springs...EVERYTHING!... the trouble im having is it gose in revs fine...netural...no od...but it jumps in drive 3, 2, and 1! when i drive in drive 3, i only get 1/2 shift. it wont shift from 2/3. it dose have a shift kit (2 check balls in the vb and case, boost valve, vb springs, accum mods,servo springs). any idea where should i start? :sweat::confused::sweat:
Discussion Starter #4
700r4 no 2-3 shift
After dropping and tearing down the trans, I found the metal line from the pump to aux vb came loose and the servo was jammed, all clutches where still new. Fluid was cherry red too! After buttoning it all up and test driving, nice firm 1-2... But still no 2-3! is there something I'm missing?
