Either tie a string from the switch to the accelerator pedal so when you floor it, it turns of the lockup, or look into Superior K058 vacuum switch and run the lockup signal through that in series with your pressure switch on the 4th gear hydraulics.I had not planned too. Im just using a switch on the dash to turn it off when not needed/wanted. Just keeping it simple for now.
I like your Avatar, here's why I have the 1:18 scale and the 1:64th scale and they just might be for sale if you twist my arm some LOL.Either tie a string from the switch to the accelerator pedal so when you floor it, it turns of the lockup, or look into Superior K058 vacuum switch and run the lockup signal through that in series with your pressure switch on the 4th gear hydraulics.
The converter clutch will let go if you unleash full power from a V8 on it. The only question is whether it's going to slip and wear out/destroy the clutch material very quickly, or whether you cut power to the TCC solenoid and deliberately disengage it.
