Very simple actually, all you need is a mechanical 'speedo bullet', drive gear and clip (on output shaft), and driven gear. (fits in bullet) There were mechanical speedos in some older TH700R4's from the factory.
The hard part is removing the old reluctor from the output shaft.
You'll need all the 'numbers' to calculate the speedo drive and driven gears. There are numerous 'gear calcs' to get it right.
