Member# 3287
I'm going to be working on my '72 El Camino and the current wiring is all cobbled up. Somewhere in my past travels, I picked up a complete (well almost) engine harness from a '72 Monte Carlo.
As I'm inspecting and repairing some minor problems with the harness, I've found some wires that I can't find in the GM schematics.
I found a green/white wire, about 18 ga, located in the harness just before the driver's headlight. It goes to a triple plug which in turn plugs into something called a "Microtemp 139C", which is white plastic. The two other wires that plug into this object are green and black.
I can't find anything in the GM repair manual.
Anyone know what this is and what it does?
plug
Doc here::pimp:
Try, Air-conditioning Thermo Fuse or Compressor plug...I think those are the colors.
Doc:pimp:
Member# 3287
Discussion Starter #3
Doc,
I think you are right. Now that I think about it, there's no wiring shown for the A/C.
Thanks.
Member# 3287
Discussion Starter #4
Doc,
I found that wiring "thingy" in the Heating/AC section. It's a Thermo Limiter for AC.
Thanks.
Thought it might be..
Doc here::pimp:
MI2600,
Yeah, I thought it might be...
So If your not going to be using AC, just get a marker on it (for next time or if you plan future AC), and tape it back..It should be all good.
Glad to hear you figured it out!
Doc:pimp:
PS: These are a good investment:
Marker Ties..
