Hi guys,
been a while since my last post. I am working on a 68 GTX with a 73 727 trans behind a 440. I Recently took the car on it's maiden voyage only to discover I have no 3rd. i have a lokar kickdown linkage to the pressure control valve and have adjusted it as per spec, even disconnected it to process the variables affecting this condition. It has a b and m transpak shift kit where two balls in the #1 and 2 position were removed and the valve body drilled as per instructions. I rebuilt the trans with all new bands and clutches, seals etc. (king master kit) and setup band adjustment according to spec. The rear clutch clearance was set to.020" front clutch .090". fluid level is fine, have even tried over adding a liter. Removed govenor and cleaned and reassembled seems to be free, 1-2 upshifts automatically crisp and on time at about 25-30 mph. Have driven in D up to 60 mph and pedaled the throttle to no avail still no third. There was no third prior to rebuild either. the shift kit was installed prior to road testing the car. any suggestions? Thanks.
