Hello guys,
So after much deliberation I've decided I'm going to replace my 12 bolt with a 9 inch Ford. The planned changes are:
1. Narrow a current 9" housing I have to get to 6" narrower than what I have now with my 12 bolt, wms to wms. Needs to pull each wheel in 3".
2. Changing gears to 3.50's +/- with a Detroit locker.
3. Going with 31 spline Moser axles.
4. Want to convert to disc brakes that I can use my 5x5 bolt pattern GM wheels with.
Sooooo these are my questions.
I am going to.use my leaf spring set up with drop shackles. I know I will need to add pads and shock mounts. What measurements do I meed to be aware of (considerimg the pinion offset on the 9") other than the wheel mounting surface distance and where the pads and shock mounts go? Difference in thickness between GM drums and disc rotors? Pinion angle with drop shackles?
Also, does anybody know of the most efficient way to get to disc brakes that will allow me to use my 5x5 wheels with them? I do not want to use wheels adapters. I'm narrowing the rear so should I use different ends when welding it back up to make the brake conversion cheaper / not as much work?
Any other measurenents or engineering issues to consider?
Thanks in advance.
Thanks in advance.
