'79 Camaro & Nova use the same front end parts. The '79-up spindles use a different outer wheel bearing from the earlier years, so that might cause a little difficulty.
Be sure you have adequate tire clearance inside the wheel well. A Nova's wheel wells are not quite as big as a Camaro's, so you might have problems with large tires rubbing.
