8.2 diff set-up?Now shims?
I must be a bit stund. Is setting up the side movement on a set of richmond shims (post gear change) not just a matter of measuring the total thickness of chev shims ,using that total thickness in richmond shims,then adding while subtracting side to side to set backlash, and using the stepped shims to center smaller ones. None of the richmond literature explained it but it seems to jump out at me as being sense,BUT even with 5-10 thou less shims in do you think I can get that thing in?uh uh, no way. Unfortunately a pontiac 8.2 diff kind of forces me to do it in place. But never the less,the total thickness of chev shims repeated in richmond shims should go in .BTW bearings the same ones
