My 41 came with a GM 10 bolt of unknown origin. Based on the drums, wheel cylinders, etc., I am thinking it is an 8.5 Oldmobile supplied out of a 73 vintage Chevelle, Cutlass, or Skylark based on the following information:
1-1/4" Pinion nut
30 spline pinion
28 spline axles (non c-clip - there's the rub)
2.41:1 gear (41-17)
11" drums
15/16" wheel cylinders
Upper trailing arm mounts are still on the housing (part of the center section casting)
So it was a coil spring rearend that has been converted to leafs.
I also have the remnants of an 89 Chevy pickup. It has an 8.5 with a 3.42:1 gear and 30 spline axles.
I want to put the carrier with the 3.42:1 gears from the truck in the 41 housing. I intend to put a Powertrax 1920-LR locker in it.
The rub is the non c-clip axles. The outfit I am wanting to buy the parts from is convinced the non c-clip rearend is an 8.2 BOP.
So, I am trying to figure it out. Tomorrow, Saturday, I intend to see if the rear covers will interchange. My question is, will this tell me anything? In other words, will an 8.2 cover fit an 8.5 rearend? If not, if they do interchange, does that pretty much guarantee they are both 8.5's?
1-1/4" Pinion nut
30 spline pinion
2.41:1 gear (41-17)
11" drums
