It is currently nice out so I went into the garage and played with engine placment. No need for sleep anyway.
Now this is where I want the engine. Further back the engine is the less the rear will want to come around on me.
From the back of the head is 39" from the center of the front wheels and 41" from the center of the rear housing with the oil pan 4.5" off the ground. The goal here is good control and a nice weight ratio so the rear does not lift on breaking or want to come around on every turn.
The engine is offset to the passenger side to match the 9" and I have not finalized the mounts. But I should be able to get within 2 degrees despite the shortness.
The issue is that the transmission I want to run( sm465 with 1410) never came with a slip yoke and I want to run a stock style 9" pinion(1350) letting me just order or slap in a diffrent ratio. That leaves me running a full splined shaft that is 8" between the u joint centers.I am guessing I can have around -2 and+4" of slip which should be more then enough.
I plan on running up to 5500rpm as a max. Mostly stock 5.3 truck shortblocks. I dont see ever needing much over 400hp.
A driveshaft this small is new to me. Maybe not to some of you guys though.
Is this a phone call or am I looking for something custom($$$)?
I have DTS "drive train specialties" right up the road. But want a refrence before I just go in there and drop several hundred with a 2 month wait when I could have used "Bobs slick shafts" off the internet saving cash and time for the same result.
