Hi I want to ask,
If I rebuild a head and put back the Cams 180 degrees out, then procced to check the Valve gap on a non-interference fit engine, when I discover this mistake and right it. Are the Valves still timed correctly?
There is no such thing as 180 out with cams. The cams determine the valve events, so as long as the timing marks line up when you go 360 at the crank (180 at the cams) you're still timed correctly
