I have an 80's camaro or firebird tilt steering column in my 37 Sedan and the wiring kit doesn't identify the horn terminal at the bottom of the column. Any ideas out there? Is the horn button just a grnd ? Thanks
Revolution Calling
Pretty sure the horn button is a grounding switch. So a 'hot' from a horn relay should make it's way up the column.
You could probe the contacts at the column plug with a DVM with a continuity check (beeps when circuit is completed) and press the horn button while checking the different plug contacts.
Or look up a schematic. :confused: :D
