If it has a factory roller cam you can see this with a rocker cover removed. First is look for self guiding rockers, these have a dimple on each side of the valve stem that keeps the rocker aligned with the stem tip. The push rod hole in the head will be round. If it doesn’t have self aligning rockers the push rod hole will be lozenge shaped in the direction across the width of the head. Both rocker aligning systems cannot be used at once so the engine will present one or the other. Self aligning rockers themselves doesn’t mean a roller cam but in a passenger car it moves the probability in that direction. As a note or two the flat tappet cam stock uses a 7.8 inch pushrod the factory (noted as “OEM”) roller uses a 7.2 inch push rod hat is not hardened. The 7.8 inch push rod can be factory hardened or not for those heads with the cast in lozenge shape guide they must be hardened for self guiding rockers they don’t need to be but hardened or nor makes no difference on these.
If the head uses round pushrod holes you might be able to see down the length of the push rod into the bottom of the valley. In the picture that Ericnova72 included you should be able to see the top of the lifter if there is a dog bone linking the lifters in pairs per cylinder and a tip of a spider leg resting on the dog bone this would have a factory or so called OEM* roller cam.
Frankly I don’t see the need to replace rockers, pushrods and especially lifters if there are no indicated problems. Changing these things can invite far more trouble than it solves especially changing flat tappet lifters. There is a modest gain to be had by changing the rockers form the factory 1.5 to 1 ratio to 1.6 ratio rockers, the engine will respond to this as if you put in a cam with about 7% more duration and lift. The factory rocker studs are 3/8ths inch diameter, so you need to order rockers for this diameter stud. Changing stud diameter and going to screw in studs is a bigger technical deal than it looks like which living on a budget in an apartment is a way bigger deal than you want to get into.
Given we’re apparently headed for a recession triggered by tech industry layoffs my fatherly advice based on 8 decades of this political/economic crap is to keep your time and financial exposure low till we see where Putin’s war is going to drag the world economy. I expect this winter is going to be a financial bit*h. With that thought in mind I’d limit my activity to a set of roller 1.6 ratio, 3/8ths stud rockers. This can be done fairly inexpensively and is a day job that presents really good results that you will feel and likely hear for the time and money invested.
* Note that these days the SBC cams are listed as flat tappet or reto-roller or OEM roller. OEM means Original Equipment Manufacturer in this case Chevrolet production line.
- Flat tappet assumed to be self explanatory this pretty much is from from 1955 through 1986 in passenger models and trucks through 1995. There are exceptions.
- Retro-Roller is the current term to define the old blind nose roller cam used to replace flat tappet cams. These can be used in 1955 and up to the crate engine era for Gen I blocks flat tappet or roller. Gen II blocks are different where with simple mods Gen II cams like the LT4HOT can be modded to run in a Gen I block but not so much the other way around.
- OEM roller basically 1987 up except for trucks before 1996 is the step nose cam it uses a unique timing set and a positive bolt on thrust plate. It’s timing gear bolt circle is different from the blunt nose cams so timing sets between these and retro-roller or flat tappet cams do not interchange. Many truck blocks from 1987 up have the provisions for the OEM roller cam. These will exist from raw casting up to finish machined an ready for an OEM roller. These provisions are raised lifter blocks for the taller OEM roller lifter, the valley cast wider to accommodate the space needed for the dog bones, there will be 3 nipple bosses on the main oil galley with each above the 3 middle main cap bulkheads. The front of the timing case will have a football shaped mounting pad sitting at an angle that mounts the cam thrust plate.
There are many excellent books out there on the SBC. I think a good basic to have is this:
Chevrolet Small Block Parts Interchange Manual [Staffel, Ed Jr.] on Amazon.com. *FREE* shipping on qualifying offers. Chevrolet Small Block Parts Interchange Manual
www.amazon.com
It gives a pretty good look at how this engine series has evolved over its long life span and is a great primer on what parts came on which engines and how they interchange where they do. You can for 25-30 bucks gain knowledge that otherwise takes years.
