OK, today I want to install the harmonic balancer and do the valve adjustment or drop the engine and install the motor mount bolts to secure it back to the frame and install the starter and oil filter to be done with under the car work.
I've heard horror stories and I've heard good stories using the install tool I bought...biggest fear is the bolt snapping off inside the crankshaft bolt hole, being impossible to get out.
I've read using grease on the threads prevents this from happening, is this true ?
When I installed this last time, I used the install tool kit loaned from Autozone with the removable tips, used grease on the threads and didn't have that problem...but I didn't have the $50 for the loan tool this time around...
