sure thing
yeah, just strip all the lean burn crap off of it, put a distributor from an older small block mopar in (easy to find) and put a regular carb on it. Is it a 2 or 4 barrel?
318s are awesome motors for reliability, torque and will run virtually forever with minimal maintenance.
They make good hot rod motors as well with a mild cam (a 268 degree 340 cam works very well in them) mild porting or some newer heart shape chambered heads or even better magnum heads, a pair of small tube headers and dual exhaust and a good dual plane intake with a small four barrel on it (a Weiand action series or Edelbrock Performer is a good choice with a 600 holley or edelbrock carb).
The biggest problem with small block Mopars of the 70's and 80's is the crappy nylon gear silent roller timing chain that wore out and stretched badly, retarding cam timing and making the ignition timing bounce all over the place. Do yourself a favor and change to a double roller or true roller high performance timing set before you put it in anything.
