Do you need a proportioning valve at all when you convert from drum to disk on the rear of a 87 Camaro, making it disk brakes front and back. Can you hard line the rear disks or should I put rubber hose at the end . I can use the existing line if I can use stainless all the way if I don't need a hose on the end.
Old(s) Fart
If you ever want to be able to remove the calipers to change the pads, you might want those rubber hoses. Four wheel disc cars use a different combo valve than do disc/drum cars. These are available everywhere.
