Or the pump died a varnishy laquered death after ground path was ressurected after 5 years of setting in the weeds.
Need to check the wiring over more, check for voltage back at the pump when turning on the key ( 2 second prime pulse)
If its getting power , have the wife crank it over to start it and pound on the bottom of the tank while she is cranking it. Maybe it will start, if it does, change the pump. The connectors can also corrode and burn up at the pump in the tank. FWIW
