Status
Not open for further replies.
1 - 8 of 8 Posts
Well i'm not a tranny expert but I have a problem with my 89 700r4 trans, what it's doing is shifting in to first no problem shift second no problem but.....halfway through second the engines revs, wants to go, but truck isn't, checked fluid "burnt" just wondering if there's an easy fix to this or am i looking for a new tranny
Thanks
Lil Vic
400SBC4Life
Thanks
Lil Vic
Will it go into 2nd manually
Explain more
my 700 started off in 2nd when my band was worn out
and it needed a rebuild
400SBC4Life
I dropped pan and it had band pieces and my clutch material was in filter (i cut it open)
and u can see it
that means a rebuild is in order
Hotrodders.com moderator
Burnt fluid
burnt fliud means to me something has worn and gotten hot in there..and if it is sliping that would mean one of the bands is shot..sounds like rebuild time to me..
Guees it is a good time to learn..folks do get the vidieo's and the parts and puzzle it out aroudn here..and we do have some tranny experts to help..
OMT
if the tranny is running fine in 2nd gear then seems to go into a "neutral" and no over-drive...... I believe the 3/4 clutch pack is the problem.
the tranny will need a rebuild if the 3/4 clutches are burned up
Rebuild!!
No it doesn't shift manually and the tranny is running fine in 2nd gear then seems to go into a "neutral" Thank you everybody i guess i'll be looking to a rebuild ....and learning alittle more myself about tranny's i'll get back to you all on helping me with this rebuild i'll be needing all the help i can get thank you once again
400SBC4Life
This is a great site to get assistance with your rebuild.
Discussion Starter · #8 ·
Well i'm glad i'll have the best behind me and any problems i get stuck on i'll be sure to ask, right now i haven't begun my rebuild yet it's been busy busy busy around here, but i'm hoping to get to it sometime this summer, Thanks!!!
1 - 8 of 8 Posts
Status
