I have a 31 Ford 5 window coupe with a Ford 9.0 inch small ford rear end with axle bearings with the O-ring seals. I have had issues with the rear end fluid leaking by the axle bearing O-ring seals. I have bought the replacement bearings that have the O-rings but would like to know if you could also use a conventional seal to help eliminate any possible leaking.
Appreciate any information anyone has.
