Save a horse, Ride a Cowboy.
I'd look to Eaton for a limited slip and compare it to Ford TractionLock limited slip. You might also check with Currie for their gear drive limited slip.
Those will run about $ 450, the gears will run about $200, the bearing kits $100, use a solid spacer kit $ 25, pinion yoke $ 90, labor to install into YOUR center chunk $ 150+.
If you need a new chunk housing $$$$.
If you need a new axle housing........$ 600
If you need new axles......$ 300 up with bearings.
Brakes, etc. ????????
