Anything with a throttle
Hello...
I am working on a 91 Chevy Caprice 9C1 police car package. There is a pretty loud protest from the rear of the car when moving down the road. It is not the brakes! A grinding sound. Could be differential~could be axle bearing. At coast the noise is still there, but with the brakes applied the noise goes away...??
Anyone...anyone...?? I believe it's a positraction rear since it is a verified police package car. If the differential is bad could anyone tell me the parts to buy to rebuild or do they sell cheaper units already together?
Thanks much...
Jeff
Save a horse, Ride a Cowboy.
Gm and new Ford rears don't have inner races in the wheel bearings. The bearings run right on the axle shaft.
Rear wheel bearings have worn a groove into the rear axle and the shift in angle is causing the axle drive gears/spider gears to make noise. Not uncommon. Install offset rear wheel bearings, or new stock bearings and new axles.
I have never had trouble with the offset bearings in my G body.
If the gears have worn enough, the noise won't get much better since there is a mis-clearance in the meshing.
